cutting fron springs.
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I am about to go from a pair of shot v6 springs to a pair of z28 springs that have been cut maybee 1 top coil at most. will this cause me to lose any handling? I kinda like the lower front end so thats no issue just the handling. i would image i would lose about 1 inch of clearance.
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
I cut my springs in the front. One coil = about 2 inches. It was a little low for my taste. When you put the coil back on make sure the bottom of the coil is inward. It didn't noticably hurt my handling, but ground clearance is an issue. If you wanna see what 1 coil looks like, check out the K member post a few down.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
im about to do this with my new MOOG springs..
Realpower...
but why does hte bottom of the coil have to be inwards?? just curious...
Realpower...
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
