who has manual steering,and do you like it?
Subscribe
View Poll Results: which is better,power or manual steering?
power steering is better
57.14%
manual is better
42.86%
Voters: 7. You may not vote on this poll
Sep 28, 2005 | 01:53 PM
does manual steering have more benifits then draw backs?
Reply 0
Sep 28, 2005 | 07:14 PM
Re: who has manual steering,and do you like it?
Quote:
i doubt it
Reply 0
Sep 28, 2005 | 08:54 PM
The only advantages to manual steering is the weight loss and the extra room under the hood from removing everything related to power steering.
You only gain a little bit of hp from removing the pump. Only a dyno would probably see the difference. The pump is only working and creating pressure when the wheels are being turned so it doesn't load the engine down all the time.
Reply 0
Sep 29, 2005 | 12:26 PM
i talked to an s10 guy with a duke and he said when he switched to an elcetric water pump he got 7hp at the wheels.
i am betting the powersteering uses at least that maybe more,and with 80hp to start,i can only go up.
i would like to drive a firebird with manual steering just to see how it will drive,i dont want to spend time and money changing over and find out i dont like it.
i have had cars with manual steering before and i liked it better then power steering,but those were all small japanese cars.
allthou with a duke i have alot less wieght in the front then a v8,so it should be easier to steer then a v8.
i guess more power is a good thing,and im not doing any road course racing,i might start on it next week.
less weight+more power is always good.
Reply 0
Sep 29, 2005 | 08:04 PM
S10's that came with manual steering were only 4 cylinder models but not all 4 cylinder models have manual steering. GM decided to put power steering in some of them. It's a cool setup. Normal GM power steering box but the pump is just a tiny belt driven pump with an external reservoir. Only on the iron duke engines though.
Reply 0
Subscribe
