how much lowering with 18s
Old Oct 20, 2005 | 08:44 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
how low can i go with 18x8 245/40/18 front and 18x9 285/40/18 in the back? and without any rubbing.
Old Oct 21, 2005 | 04:20 AM
CrazyHawaiian's Avatar
Car: too many ...
I'm running very similar sizes (except I'm running 275/35/18 rear) and I've lowered it well over 2 inches without rubbing. Your wheel backspacing and the rest of the suspension is important. Going with a close to stock backspacing in the front gives alot more clearance at extremely low ride heights, but then when compared to the rear wheel (which can have a more extreme backspacing without rubbing issues) the fronts can look like they are too far in or inset. So keep that in mind. Also the rest of the suspension needs to be in top condition and modified to properly support the ride height or it will bottom out and cause you to rub (example, need good struts/shocks).
Old Oct 21, 2005 | 09:55 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
are sportlines to much of a drop?
Old Oct 22, 2005 | 02:07 AM
Kandied91z's Avatar
if your offset is right the ground is the limit..
Old Oct 22, 2005 | 04:16 AM
Car: too many ...
You will be fine with sportlines, I've verified it. So have a few others currently running that setup with 18's (I've since then changed my setup)
Old Oct 22, 2005 | 03:06 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
i love the way powermites car looks with 18s and 40 series sidewall all around and he has a 1" drop. is this enough to cover the fender gap?
Old Oct 22, 2005 | 06:32 PM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
Hey, what kind of wheels are those? almost look like kenesis. But I know those are major$$$$. So I asume they are not.
Old Oct 22, 2005 | 09:13 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
image wheels
Old Oct 23, 2005 | 03:37 AM
Kennerz's Avatar
Thanks, are they good wheels, or expensive?
I'll be getting wheels for my ride in the near future, and always keeping my eyes open for the "right" wheels. willing to spend $300+ per wheel but not much more, many of the quality custom wheels are just so outrageous in cost- can't see paying $750 or even $1k for just a wheel, end up having wheels that are worth more than the whole car, even though thirdgens that are done right are still gettin $7~$10k on the market out here, and nice GTA's and Irocs will be gradually going up as they approach the 20yr mark. People at some point will want them again. especially with there not being as many interesting new cars on the market, that are under $35k
Old Oct 23, 2005 | 01:39 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
i think they cost more than $300? not sure. search for image wheels in google or something.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
