Wonderbar... TDS or Spohn
Old Oct 22, 2005 | 05:30 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I'd like to add a wonderbar to my 91 GTA. The only 2 sources for this prodcut I found were TDS and Spohn. Which manufacturer/distributor should I go with? and second... if I go with Spohn, should I get the adjustable wonderbar or the unadjustable version?
Thanks!
Bill
P.S. My car only has 50K on it. Should I expect any subframe damage? How can I check for any damage due to lack of wonderbar?
Old Oct 23, 2005 | 07:07 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Go with TDS. Spohn's design can cause issues with the fans and also some swaybars. TDS can't be faulted for service either.
If you want more details, do a search as this has been discussed to death.
Si.
Old Oct 23, 2005 | 07:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Long before TDS or Spohn manufactured the Wonderbar or SFC's, there was Globel West (an often overlooked company whose products are first rate. I'm running both their Wonderbar and SFC's). I've dealt with all three companies and all have fine products.
http://www.globalwestsuspension.com/...OVMTC=standard
By the way, I installed a 36mm front sway bar and dual electric fans without any problems whatsoever.
JamesC
Old Oct 23, 2005 | 12:29 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
Just ordered a TDS wonder not sure about the product yet but the service was awesome. I ordered it and it went out UPS the same day!! Now that is service.
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
luvofjah
Sep 26, 2015 08:28 PM
