dropping rear end?
Old Oct 28, 2005 | 12:32 AM
Kaukasion's Avatar
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
dropping rear end?
i plan on taking the rear end out as it has gotten rusty as hell over time
but im paranoid im going to **** the chassis some how
where should a lift and support the car from to remove the rear end?
and any quick tips anyone has about dropping it out that could save me some time please add
Old Oct 28, 2005 | 01:22 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Put the jacks forward of where the rear control arms mount to the rear subframe rails.
Easy to see, just follow it from where the control arms mount to.
AS far as dropping it, its easy as pie.
Disconnect brakes and plug the line(unless u want to rebleed the whole system master cylinder included)
Than undo the emergency brake cables and driveshaft and torque arm bolts.
Then unbolt the shocks and than the control arms with the rear suspended.
Should be a pretty quick job
later
Jeremy
Old Oct 28, 2005 | 01:30 AM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
so toward the front of the arms about where rear door jamb is would be ok?
also the motor is out will there bee a teetering sp? problem?
the rear of this thing is prolly heavier than the front right now
and i also have another posi rear im pulling soon out of a donor car *(the one that gave me the l69)
im robbing the calipers off of it for my trans am but other than that i plan to sell it
if anyone is interested let me know and name a price
Old Oct 28, 2005 | 01:53 PM
91Z-TheReaper's Avatar
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
Right where he mentioned is perfect, won't teeter at all. I just did this swap last weekend...took out 2.77's and put in 3.42's...
You might want to have another jack sitting under the rear end as well, so when it drops, it doesn't drop to the floor, then you can slowly lower it and roll it right out.
Go here for a few pics. Not very detailed, but I think you might get to see the jack stands...
RearEnd Drop
Good luck...
Old Oct 28, 2005 | 02:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
when i did my rear swap a while back i set the jacks in teh same position everyone else mentioned above, however i only jacked the car enough so that the axle was still resting on the ground, i remove the brakes from the axle but left it all in tact to the calipers. after the torque arm and driveshaft were removed, and i dropped all teh suspension components, the axle rolled right out.
Old Oct 28, 2005 | 09:27 PM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
ok we got it done
it didnt take very long at all
involved alot less work than i thought it would
thanx for the help guys will post pics when i get mine done and painted
Old Oct 28, 2005 | 09:38 PM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
hey anyone ever use evapo-rust?
i was wondering if it would work good i bought a bottle to soak the calipers in before i paint them
if it does anything it claims it will save me a good deal of time
also if you have used it do you have to clean (soap and water) the surface after submersing before you paint?
thanks guys gonna get this thing back to new looking and order all the poly bushings
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
