Question about LCA's?
Old Nov 5, 2005 | 06:07 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
What would happen if one end was a solid steel grease-able rear bushing and the other end a rod end.Saw a set with these two ends on them.
Old Nov 7, 2005 | 02:48 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
i believe spohn makes the with one end with poly bushings and the other rod ends, other than the cost factor i dont really know the advantage of mixing the two.
Old Nov 7, 2005 | 03:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I would think that the solid steel end would bind.
Old Nov 7, 2005 | 04:32 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
I know of a few companies that make LCA's with the poly/rod combo but what I'm asking about is a solid rear bushing/rod end combo.And Aperion that's what I was thinking.
Old Nov 9, 2005 | 02:56 PM
Car: 91 z28
oh i see, i have no idea really why they would use solid steel bushings, i know i had CE slide-a-links in my s-10 and i had to put solid aluminum bushings in the leaf springs, but i wasnt sure why exactly
Old Nov 16, 2005 | 08:34 PM
Creak's Avatar
Car: IROC
Engine: 5.0L
Transmission: 5-Spd
A solid bushing would bind and the ride might be harsh. I would only recommend that for a drag type car. If you want a set up like that get at least poly bushings on the one end and good rod ends, the cheap rod ends rattle
Old Nov 16, 2005 | 09:38 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Yeah!!! Like the ones that I got..
https://www.thirdgen.org/techbb2/sho...hreadid=327822
Old Nov 20, 2005 | 02:11 PM
Creak's Avatar
Car: IROC
Engine: 5.0L
Transmission: 5-Spd
Yeap thats actually what I meant, performance is great too. I run the ones from UMI, very nice just as the Spohn ones are. Good Pics.
Americanmouse
Sep 7, 2015 12:10 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
