relocation bracket?
Old Nov 27, 2005 | 09:27 PM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
relocation bracket?
I am planning on putting a TH400 in my GTA with the spohn kit and I want to run LCA relocation brackets. If I do will I have to have adjustable LCAs or can I just run fixed length. Thanks for the input.
Old Nov 28, 2005 | 01:00 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Fixed length is fine.
Old Nov 28, 2005 | 10:43 PM
355gta's Avatar
Engine: 355
Thanks. I was hoping they were. I plan on setting the pinion angle to -2 degrees and experimenting from there.
Old Nov 29, 2005 | 01:04 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
1. An adjustable torque arm is needed to adjust the pinion angle. 2. An adjustable LCA centers the wheel in the wheel arch.
3. Not asked, but an adjustable PHB centers the rear end side-to-side.
If you lower the car you'll need #1 & #3, not #2.
Lon
Old Nov 29, 2005 | 08:54 PM
355gta's Avatar
Engine: 355
Thanks lon. I am not planning on lowering it. I am just going to run drag shocks/struts and launcg springs. If anyone has a suggestion of what brands let me know. Thanks
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
