Steering Column Connector- How to disconnect??
Old Jan 6, 2006 | 12:50 PM
aroc's Avatar
I an installing Edelbrock headers on a 1992 camaro with a 305. Instractions say to disconnect steering column connector and slip tube down to steering box. I assume the column connector is the piece about 8 down the column from the firewall with a plastic protector around the lower part and some rubber on the bottom. I took out the bolt but nothing slips apart. I tapped on it a little but it did not want to move much. Am I in the right place.? How do I get it to slip down?
Old Jan 6, 2006 | 01:13 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Well, i have never installed Edelbrocks but never had to disconnect the steering linkage to install headers. Anyways, they are hard to move sometimes, if you can tap on it with a hammer near the top it will ususally slide down enought to get it off the column. you may have to unbolt it from the steering box at the bottom to get it to move. or to remve it completely........jt
Old Jan 6, 2006 | 08:47 PM
aroc's Avatar
I got it apart with a lot of gentle tapping.
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Night rider327
Sep 25, 2015 04:19 AM
