RS / WS6 differences?
Old Jan 10, 2006 | 11:06 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I found a 91 WS6 Formula for $150. What I want to know (other than the obvious sway bars), are there any differences in the suspension? I am mainly interested in the front (tie rods, end links, center links, idler arms, etc). Thanks.
Old Jan 11, 2006 | 11:10 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The WS6 is going to have bigger sway bars, stiffer durometer suspension bushings and springs, 12:1 steering box.
Unless the RS has F41 its going to have a pretty soft suspension. Even then, F41 is still not quite on the level of WS6.
Old Feb 7, 2006 | 09:21 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I found out that I have F41. What is that exactly. I drove what I beleive to be a non-F41 car, and it was SOFT. I hated it. Would the WS6 springs be better than Eibach Pro-Kits?
Old Feb 7, 2006 | 09:45 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
tie rods, end links, center links, idler arms...all the same.
ws6 springs i believe are slightly softer than the eibach pro-kit...and the springs may be just as wore out as what you currently have..
ps- im dissapointed with my pro-kits stance.
Old Feb 7, 2006 | 09:47 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I have them already. Stance is ok, but they need to be stiffer IMO. I also need stiffer shocks/struts. They are CRAP. Monroe sens-a-nothing. I mean, they were good with the stock springs, but the Eibachs killed 'em.
69GTOby
Apr 18, 2016 02:34 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
dbrochard
Sep 7, 2015 09:41 AM
greenyone
Sep 2, 2015 03:39 PM
