URGENT- Steering wheel loose- 87 IROC-Z
Old Jan 11, 2006 | 02:54 AM
Paul Taylor's Avatar
Car: 1987 Camaro Z28 IROC-Z 5.0 V8 TPI Auto, with 125hp shot Nitrous
Engine: 5.0 TPI
Transmission: 700-R4 with Shift Kit.
Hi all,
On the way in this morning i noticed my steering wheel was loose.
Well is hard to say exactly, but if i press on the wheel in the 12 -3-6- or 9 o'clock positions the wheel will move about 5mm.
If i pull or push the wheel there is no free movement.
Its almost as if the Hight adjuster has come loose.
Anyone got any ideas ???. Is it Dangerous ?
Think im gonna have to hire a car again for the rest of the week.
Question also posted on UK Camaro forum.
http://www.aacint.com/forum/topic.asp?TOPIC_ID=16091
Old Jan 11, 2006 | 07:46 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
A loose tilt column is fairly common and there's a tech article that can walk you through tightening. Might be an afternoon job if you've never done it before. There are four screws that loosen and you can get to two of them without pulling the column hinge pins (pita). Tightening the two lower is a 2-5 year fix for most.
morrow
Jan 13, 2024 12:29 PM
SlowAZ28
Aug 31, 2015 07:56 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
