16's in the front 17's in the back??
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
Well I am having a lot of problems with rubbing and hitting with my 17x9" zr1's and 275 nittos, so I was concidering getting 2 16x8" zr1's and put some 235/245 tires up front and calling it a day. Anyone have any opinions on how it would look? Would it make that big of a difference looks wise? Anyone do this and have pics? Thanks for the help.
Chris
(Pic in Sig)
Chris
(Pic in Sig)
Engine: Cammed 6.0L LSX
what size spacers are you doing? and is your car lowered? you need 2" spacers if you dont have them already
Car: '02 Z06
I think it would terrible honestly. Staggered setups don't look too good on these cars at all. What you have now looks great. Not too sure why you would want to go to a 16? Wheel diameter doesn't make a difference, if you choose the right sized tire you won't go over stock tire diameter anyway.
Ideally you should be running a 275/40. If your running a 275/45, your an inch over stock diameter and this will cause your rubbing issues.
Nice car by the way.
Don't they make a 17 x 8 fourth gen style ZR1 wheel? I thought they did but could be wrong.
Well I ran out and checked and they are indeed 275/40/17. Would going to a 275/35/17 do the trick? Although I would imagine that would be a rather low profile tire.
And to answer BlueZee's question, I am using 2" spacer...might be 2 1/8" spacer. The car was lowered 1" with a prokit before, but I am in the process of getting some custom springs from ground control that will raise the car back right around stock height(or maybe slightly lower) with a lower spring rate for a more street/strip oriented suspension.
Car: '02 Z06
No I was thinking there were fourth gen offset wheels in 8". You wouldn't want to run those it due to lip, finish, and center cap differences. There are plenty of guys running 275 in the front so I would do as much research as you can before making a decision. One thing's for sure, that's a really sweet car I would hate to see you settle for 16's in the front. Then of course there is always the option of selling your wheels and looking into a different design, maybe even a custom built to your specs billet wheel.
Car: '02 Z06
Originally posted by 92CamaroLS1
Haha...I couldnt imagine what a custom wheel would cost...not in the budget of a 19 year old college student, ill tell you that lol. I tried to use a heat gun to bend the inner fender plastic, but that didnt turn out well so I decided not to make any more of a mess with that. I was also going to clearance the metal part of the inner fender but I didnt realize that it was so hard and a hammer wasnt going to do the job. Im not sure what to do now actually.
Maybe make a post in the suspension board. You'll likely get some good feedback there.
lol, I saw the word "LS1" so I came to the conclusion you had a bit of change.
Car: 89 Formula 350
Engine: 355
They also dont sell them in chrome, or individually, so I dont think I could go this route, although it would be nice.
http://www.slponline.com/view_produc...03&BIG=81003-1
Originally posted by Lunatic0987
Here are the ZR-1's in chrome that were designed to fit 3rd gens. Is this what you were talking about?
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
didnt stop me lol......but for how tight my budget is now I wish it would have
....and I thought diameter eventually plays in a role.....the fact that on my 18x10's I was told to run a 35 series tire, but if it were my fronts which are 8", I can run a 45 series, and if Im right, they will be the same height?.....I never understood that...am I way off track on this, and someone could clarify this for me?
Car: 91 Z28
Transmission: built 700R4
just throw on some 255/40/17s on the front or 245/45/17 and don't worry about it anymore.
I have had 255/40s and I have some 255/45/17s on my 17x9s right now, the only time I rub is when backing up full lock.
P.S. I have sportlines too.
Car: 91 Z28
check out my cardomain page, I had the 255/40/17s on the TT2s and the 255/45/17s on the RTs. I don't recoment the 255/45 combo, it is alittle too tall, should have stuck with 255/40 or 245/45. The later is what the size the 00ish mustangsGTs come with.
I just noticed though Camaro05 that you have 17x8" rims, and I have I believe 17x9" (possibly even 17x9.5")...so will a 255/40 fit on that wide of a rim?
*Edit: I just found out that a 255 will fit on a 9 or 9.5" wide rim so Im good on that route.
The only thing Im concerned with is if by going from a 275 to a 255 will actually fix the probelm. Its a relativly inexpensive route so I might try it.
Originally posted by Ace
what sized spacer are you running.. maybe you need to kick it out a bit more..
I also have not gotten the car aligned yet, and the camber is clearly too negative...if it was corrected to 0* would it make any improvement? Although its hard to say now because I have new springs coming.
Well I went out and measured and it turns out to be a 2" spacer with another small 1/8" spacer for a total of 2 1/8". Could it be pushed more and would that help my rubbing problem?
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
do you still have the stock k-member in there? i was lookin at some pics and it doesnt look like your front wheel is centered in the well, it looks too far towards the door.. i think you were using the hawk tubular stuff if that would throw it off that much, could also be the tires at a slight angle.. not sure :|
Car: 91 Z28
I am actualy running the 255/45 on my 17x9 RT rims, so a 255/40 is slightly wider and has a lower profile and should work verry well.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I know your setup is much different and I'm not sure exactly where yours rubs. I put 255/50/16 on the front of mine and I had more rubbing with the "front" wheels. So, I switched to the "rear" wheels and had less rubbing. I had them spaced out too much, but I don't think that's your problem.
I'm guessing your rub issue is at full trurn, and between the outside edge of the tire and the back of the fenderwell by the door? - yes, caster/camber will effect it. Get it aligned. Also, if you can get by w/ a little less spacer, that can help. drop the 1/8 out(if it doesn't put the tire/wheel into the strut) and see if it helps.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
I just got the SLP ZR1 styles (17x8) with 275/50 back and 275/40 front. I had minor rubbing on the back (had to roll up the lip on the wheelwell) and the fronts fit with minor rubbing at full lock in reverse or over bumps when suspension compressed. Otherwise, for all the people asking if the 255s will fit on a 8'' or 9'' wide wheel, I have 275s on my 8'' wide wheel. Just an FYI... and the 275 look wicked on 3rd gens....
Car: '85 Z28
Car: 1991 Camaro RS
Engine: L98 350 TPI
As soon as i give her a bath, ill take some pics and post them.
