swaybar removal questions
Old Jan 15, 2006 | 12:07 AM
muteboy49's Avatar
Car: 84 Camaro
Transmission: dont have one yet
Axle/Gears: 3.42 spool on the way
im gonna take my swaybar off and was wondering what kind of issues i will have driving it on the street if any
Old Jan 15, 2006 | 01:04 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Aside from wallowing through the corners none.
Lon
Old Jan 15, 2006 | 09:20 AM
BOTTLEDZ28's Avatar
Transmission: A4
I wouldnt drive my car on the street w/o a front sway bar. You wil have some serious body roll when turning. If you are careful, then maybe going to and from the track but thats it.
Old Jan 15, 2006 | 09:52 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
If you are taking off the front swaybar and dont have a rear bar yet then you should definately get one.. It will help with the body roll around turns a little and also help control wheel hop.
Old Jan 15, 2006 | 09:56 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
What reason do you want to remove your sway bar(s) off?If for weight transfer at the drags you can just unbolt the ends links and safety wire the ends,or get sway bar diconnects.You'd be surprised how mushy the car handles in corners with no sway bar,like Lon said.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
