New Eibachs, have questions.
Old Jan 22, 2006 | 03:45 PM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
i just bought some eibach pro-kit springs, but im kinda starting to second guess myself after reading all the posts about lowering these f-bodies. pretty much my goal is to do some subtle suspension upgrades, a field that im not TOO familiar with. so i figured id start with basic lowering springs. i dont want to get wild at all, especially since i cant go welding on relocating lca's etc. i really just want more of an agreesive look with mild VERY mild upgrade to start out with. so what else do i absolutely NEED to lower the car aside from some good upgraded shocks and my pro-kit?
sorry that was long winded, just wanted to be clear.
thanks guys! you never let me down!
Old Jan 22, 2006 | 04:38 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Re: New Eibachs, have questions.
You will need an adjustable Panhard Bar. I'm using this one:
http://www.spohn.net/product.cfm?productid=1297
thats about all you ABSOLUTELY need. but i would recomend sub-Frame Connectors, and LCA relocation brackets.
Old Jan 22, 2006 | 05:10 PM
alright cool, yeah that stuff will come later on down the line, but i just dont want to get into it all at once, since im still learning. thanks for the help!
Old Jan 23, 2006 | 03:42 PM
Roads88's Avatar
Car: 1988 Pontiac Trans-AM
Engine: TPI 350 (5.7L)
I did the same thing you did (see Sig) my old shocks, struts, and springs were so worn out, The car looked like it actualy lifted.
Mine are the set with the one (1) inch drop. looks will not change much, but handling is great!
Old Jan 23, 2006 | 03:45 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
yeap same here, i replaced the shocks/stuts and put in a pro kit and the car maybe lowered 1" is all. The springs i had in it had about 95k miles on em. Pro kit wont slam your car but will drop it a hint and make it handle like a SOB
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
gta_knight
Sep 23, 2015 04:59 PM
jbates346
Sep 22, 2015 05:22 AM
