Floor Pan Advise
Old Feb 8, 2006 | 04:42 PM
3rdgenfever's Avatar
Car: 89 IROC-Z & 92 RS
Engine: 350 TPI & LQ4 408 in the works
Transmission: 700R4 & T-56
Axle/Gears: stock/ LT1 disc 3.42
Floor Pan Advise
I AM CURRENTLY MODIFYING AN 83 Z28. BOTH SIDE FLOOR PANS HAVE TERRIBLE ROT. I ALREADY HAVE NEW FLOOR PANS FROM CLASSIC INDUSTRIES. STANDARD 82-92 PANS. HAS ANYONE EVER PUT NEW ONES IN AND IF SO WHAT SHOULD I LOOK FOR. DO I NEED TO BRACE ANYTHING FOR BEING A UNIBODY IN ALL, PLUS T-TOPS. ANY ADVISE WOULD BE AWESOME!
Old Feb 8, 2006 | 05:37 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
Cut the old ones out, weld the new ones in.
You could try adding some bracing... Usually you want the bracing attached to something stiffer though such as the SFC, unibody frame or controls arm mounts.
Ben
PS Turn off your caps lock, plaese.
Old Apr 28, 2006 | 08:02 PM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Hey Nicky
You have SFC yet? If you don't I would try to find some old SSM ones they tend to tuck up in the vehicle real nice like.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LC2 TECH
Oct 13, 2015 11:53 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
