#%$&*^()! frame
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
#%$&*^()! frame
well i finally bought another camaro,but i guess it wasn't meant to be.my first was a 88 until it burst into flames,and i loved it.this is an 84. when i looked at it before ibought it the frame looked good.it was decieving! the whole thing moves !where its welded to ,frame and all.this sucks.is there anyway to fix it?it's not broke anywhere,but it all moves.
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
First thing I would do is take it to a good alignment shop. If the frame is straight but flexible, that can be easily fixed. If it's bent and flexible, that sux.
IMO, the 1988+ years are better, Gm had electronics figured out a little better and didn't rely on vacuum lines so much. They are also a little less abused... usually.
Ben
Ben
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
this is in the back.it's because the floor board in the back rotted out.i don't know where to buy another floor panel???it looks as if the frame was welded to the bottom of the floorboards.
Car: 91 Camaro RS
I think most people just cut and weld sheetmetal to fix those holes. If it's still too flimsy, weld a brace between the rear frame rails.
Ben
Ben
Car: 91 Camaro RS
Good luck.
If you know how to weld your in great shape. If not or even if you do, check out the fabrication section. Lots of good tips there to make your projects come out nice.
Ben
Ben
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
