Sway bar rubber??
Old Feb 25, 2006 | 09:42 AM
airbrushguy's Avatar
Sway bar rubber??
I just need to replace the rear sway bar link bushings and the ones that are clamped to the rear axle. Does anyone sell just these pices separately? Maybe new clamps also.
Old Feb 25, 2006 | 10:05 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
One our sponsors at the top of the page TDS sells them.You can buy just the bushing but it's best to get the complete bushing/clamp as they have grease fittings in them.Lon is a great person to deal with.
Old Feb 27, 2006 | 03:29 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
If you're existing parts are not new/have-been-replaced-recently I would get entirely new pieces. Unless the price difference is radically different (altho my sway bar endlinks wer $10, $15 for the center parts). I suggest new part because mine were disgustingly rusted, as most parts on these 15 to 25 yr old cars would be.
Old Feb 28, 2006 | 10:13 AM
CrazyHawaiian's Avatar
Car: too many ...
I usually just clean up the old bolts and stuff and run new bushings. If its rusted I lightly sand it with sandpaper until the rust is gone. You can get the new bushings all over the place. Local parts store will probably have OE replacement but if you want aftermarket stuff check out Energy Suspension or PST. Remember not to overtorque those endlink bolts when putting it back together.
Old Mar 1, 2006 | 08:59 PM
coolram62's Avatar
Engine: LU5 305 CFI
One thing on reusing the old parts clean/inspect them completly.My front end link bolts,bushings were completly gone,had wear spots on them.And it's good to either add nylon lock nuts or use lock washers.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
