295 50-16 will they fit a factory iroc 16" wheel well enough to rely on?
Old Feb 27, 2006 | 12:37 PM
woncamaro's Avatar
Car: 1986 IROC Z28
Engine: 355, all edelbrock performer rpm
Transmission: 700r4, B&M shift kit
I put 295 45-17 kuhmo ecstasa tires on my wife's mustang and they work out well, but I am not sure what size wheel her car has on the rear. It is a torque thrust wheel which comes on the bullet mustangs. I would like to run the bfgoodrich 295 50 16 on my iroc, but am not sure if the foot print would be as large as it has potential to be with the rim size being narrower and all.
Old Feb 28, 2006 | 11:26 AM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Wheel Size
Most people will recommend no larger that a 255 for a stock 16" wheel, the size you suggested seems to large. At least, thats my understanding of what I have read and been told. Some can feel free to correct me if I'm wrong.
Old Feb 28, 2006 | 11:55 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
worked well for me, you'll have to do some major inner-fender well massaging to get them to fit though.
BFG designed these to work with an 8"-10" wheels, being that the iroc is a 16x8, it works just fine. has more sidewall bulge than most people on this board like though, but it seems that if you don't have at least a 17" diameter wheel, your not cool anyhow.
Old Feb 28, 2006 | 02:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
nova, I remember you had 275's on your 15x7 camaro wheels....
do you have a picture from the rear of the 295's?
I've got 15x8 wheels, and 275's in the rear, I LOVE the look of it, but i'm greedy, and will probably move to a 295 later.
Old Feb 28, 2006 | 02:45 PM
woncamaro's Avatar
Car: 1986 IROC Z28
sounds good to me. I am running the 275 60's right now and they keep hitting the top of the fender well. About the inner fender work; did you just run a hammer along that sum bitch or what? I hammered the hell out of mine already to fit some daddy slicks, so I hope I won't need to hammer much more. I really don't have any more room.
Old Feb 28, 2006 | 05:49 PM
Shagwell's Avatar
Car: projects.......
- why run a tire that's built for a rim 2 inches wider than what you have? Especailly when you can get better traction out of tires that actually fit right? BFG T/A's are crap for traction. I've seen better 60fts out of Fulda's, which aren't a great tire(great true street tire, but nothing compared to DR's), and they were only 255's as compared to the 295's. Also, it's hard to get them to wear even, when they're trying to pull the corners of the tire up becasue of the sidewall being pulled in so far. It can be done, but you'll have to play with psi, and re-check/re-set it often.
woncamaro - 275/60's are taller than 295/50's, but the 295's are a bit wider.
Old Mar 1, 2006 | 12:57 AM
mw66nova's Avatar
Engine: 7.0L
from the rear:
and a video showing it from the rear, this is with my old 305.
http://www.jimmybiggstv.com/yourway/jama/mov00519.mpg
Old Mar 1, 2006 | 11:27 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
A bulging tire like that will NOT help your cornering...
mw66nova:
My eyes are still stinging from the blue smoke when you revved up your dying 305 How many miles did you have on it when it got pulled?
Old Mar 2, 2006 | 12:46 AM
mw66nova's Avatar
Engine: 7.0L
about 40K HARD miles. the blue smoke was attributed by the broken piston ring lands on #7.
Old Mar 2, 2006 | 11:59 AM
Engine: LS3
Transmission: 6L80E
mw66nova:
That sucks ...but otherwise, nice car
Thread Content: I should have added that in general, people will try to fit the fattest tire they can physically wrestle on the rim, without taking into account the much greater stress on the sidewall. This results in not only worse traction and cornering, but can actually lead to the tire popping off the rim in an accident situation...A good friend of mine who deals with a lot of collision repair can attest to this...
HTH...
Old Mar 2, 2006 | 12:46 PM
mw66nova's Avatar
Engine: 7.0L
these tires are designed for a 8"-10" rim though. look on BFG's site.
Old Mar 2, 2006 | 01:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
nova, those look pretty slick. Too bad for the shadows under your car.
I'll have to see what backspacing is on my 2nd gen snowflakes, see what kind of fender beating i'll need to do in the future.
Is the 350 in and running yet?
Old Mar 2, 2006 | 02:51 PM
mw66nova's Avatar
Engine: 7.0L
found a lighter picture taken at the same time:
yes, the 350 is in and running. just got the double pumper back on and timing set. hello 11's! should dangle the front tires some too!
Old Mar 2, 2006 | 06:17 PM
Engine: LS3
Transmission: 6L80E
mw66nova:
I think the miscommunication here is whether they "will fit" or were "designed" for a certain size rim.
Certain manufacturers' websites used to specify a recommend rim size along with a "will fit" column too...now the BFG site just has the "will fit" column.
For my business, I do a lot of work with a Tires Plus branch locally as well as a BFG distributor, so I asked them...They advise against choosing out a tire that is on the max side of the "will fit" column according to the specs on the website.
Frankly, I think they should be more honest about it on the website, but I suppose they sell more tires with the way it appears now.
Old Mar 2, 2006 | 09:19 PM
mw66nova's Avatar
Engine: 7.0L
well, from personal experience, they fit fine, however, i do not push my ride to the limits going around turns etc., my car is a straight line performer.
Old Mar 3, 2006 | 12:22 AM
Engine: LS3
Transmission: 6L80E
Would you be concerned about rubbing during hard cornering?
I do like the look of them, but not like the spongy sidewalls...
Old Mar 3, 2006 | 02:42 AM
mw66nova's Avatar
Engine: 7.0L
on a car with no inner fender well modifications...yes, i'd be concerned, however, mine were modified for it to fit via my BFH and some fender lip rolling as well.
Old Mar 13, 2006 | 08:12 AM
91'ss''s Avatar
Car: 91 RS -- "SS"
Engine: 305 TBI
Transmission: WC T5
my dad used to have BFG 295/50/16's on his iroc wheels in the back. they looked ncie and fit fine but...he had some wider wheel spacers on the back. over some bumps and turns if you were goin even just slightly fast, the tires would rub on the iside lip of the wheel well. so after a while they had a kinda nasty lookin edge around the outside of the sidewall. also, i dont htink they cought traction as well as the 245/50/16's do that are on it now.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
kah992
Aug 19, 2015 02:55 PM
fonzie85
Aug 13, 2015 11:50 AM
mustangman65_79
Aug 11, 2015 03:17 PM
