TDS wonderbar install question
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I'm ready to install the wonderbar on my car, but I'm not sure if i only need to remove the two main bolts that hold the sway bar onto the brackets, or if i should remove all 4 bots which include the 2 bracket bolts...on the wonderbar, there are 4 holes or openins on each end....what is the best way to install the bar? thanks.
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Did you read the instructions? http://www.top-downsolutions.com/Doc...structions.pdf
Lon's instructions are very good and they answer your question.
Car: 1988 SC Camaro
Engine: 305 TBI
Did anyone notice that there are (4) bolts on the passenger side bracket and only (3) bolts on the driver side?...i wonder why that is...
84z96L31vortec
Aug 20, 2017 12:16 AM
