modding stock pan hard bar?
Old Mar 25, 2006 | 08:00 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
One of the fox body friends has a turbo notch and he has a supped up suspension. One of the things he did was take the stock pan hard and welded it up. He said they are better than after market ones and he can launch that car into next week. I was wondering if welding up our stock pan hard and support would be worth it? I have someone who can do it cheap.
By welded up, I mean this:
 __
/&nbsp;&nbsp;&nbsp;\ <- stock
&nbsp;__
/__\ <- welded
crappy diagram, but i think it gives the point.
Old Mar 25, 2006 | 09:24 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
That is not better than an aftermarket tubular PHB
Old Mar 25, 2006 | 09:36 PM
Souseless's Avatar
Car: 89 WS6
The problem is the rubber bushings during lateral loads. Rod ends are what work best. If you are only drag racing it probbably does not matter.
Old Mar 26, 2006 | 03:08 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you mean boxing it. welding in a strap of steel. I've done that to mine. Cheap and easy. Also, poly bushings for the PHR are only $20USD, and you can easily put them in yourself (unlike those godforsaken lcas....)
Yea, not as good as an aftermarket tubular, but definately better then stock, i'd say go for it, what do you have to lose right?
Old Mar 26, 2006 | 08:00 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I welded mine up and installed poly bushings and I think it works fairly well actually. just be careful welding your panhard bar, I welded mine and got a tad too much heat in it and now it has a very slight bow in it. not enough to really matter, but i did warp it just the same. Just a heads up.
Old Mar 26, 2006 | 10:56 AM
Car: 88 Camaro
Engine: 310 LG4
I planned on getting some poly's for them since mine are the original 18 year old bushings. I will keep that in mind. My brace is already bowed a bit, gotta fix that. The V6 was a beast
Thanks for the input.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
