wonder bar or hotchkis strut tower?
Car: 89 WS6 formula firebird
Engine: 305 TPI :(
im not edumacated on either of these, but do they do the same thing? and which is better, im already aiming towards the wonderbar due it its price and its millions of praises Senior Member
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
They both do similar things. The wonderbar braces the frame rails between the idler and pitman areas. The strut tower brace stops flex in the strut towers.
I would add a wonderbar first since there's no drilling involved. Plus it can prevent cracking of the frame around the steering box's mounting area.
I have the TDS version of the wonderbar and would recommend it. Install is a snap.
Engine: 305 TPI :(
could somebody post a pic of theres installed, i thought it went on top like a strut tower but its on the bottom?
Engine: 305TPI
It's on the bottom sandwiched between the swaybar and the frame. Here's a picture of a stock version wonderbar installed. It's not my car.
Engine: 305 TPI :(
ok i see, but ok so i might as well replace my sway bar bushings if i do this, wat size are ws6 swaybars. and thank u jade for the fast and helpful responses
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Get some kind of adjustable wrench (I actually used vise grips once) so that way you can tighten them so they just pass over to get the diameter. Then, go to safeway, albertsons, something like that about buy a $1 ruler and compare it on the metric side. WS6 fronts should be 36 MM but it's good to check and easy.
Oh yeah, get the wonder bar, no drilling, 6 bolts, it's a piece of cake. I personally think TDS makes the best one hands down.
Last edited by Joez88Camaro; Mar 29, 2006 at 12:48 AM. Reason: Automerged Doublepost
Engine: 305TPI
Just fork out around $3 and buy a little pocket caliper like a General Tools Model #132 or equivalent.
It's way easier when measuring swaybar diameter.
LT1Formula
Oct 8, 2015 08:34 PM
