steering poping
Old Apr 3, 2006 | 02:32 PM
blksiryder's Avatar
Car: 1992 camaro rs
Engine: 3.1
steering poping
i have a 1992 rs v6. when the car is on the ground turn the wheel all the way to the left it makes a poping noise close to the stopping point. for me to get it to do it again i need to straighten it out move fwd or back just a little then turn it all the way over again. all ball joints are good and the inner/outter tie rods are tight. could this be a steering box going out.
thank you for the help
Matt
Old Apr 3, 2006 | 05:00 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
strut mounts or double check ball joints. maybe control arm bushings. check to make sure all 6 bolts holding the k member are still there and tight
Old Apr 9, 2006 | 10:56 AM
blksiryder's Avatar
Car: 1992 camaro rs
Engine: 3.1
well everything is tight. but i have that dust cover that sits near the gear box that is off the line. so the dust cover moves up and down and spins when i turn the wheel. anyone else this this could be it.
Old Apr 9, 2006 | 05:31 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Steering box frame rail crack?
I dunno my gf's car used to do it. This was also before we put all new tie rods/centerlink/idler arm/ and a iroc-z quick ratio steering box. Oh and also a TDS wonderbar...all that fixed the steering poping noises at full lock when parking and such that we used to hear.
Old Jun 27, 2006 | 10:24 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Have the same thing goin on in my 87 TA. If you look at the pitman arm while someone turns the wheel..see if you have play in that. My problem is my steering box. Must be worn on the main shaft bearings or something. It pops back and forth pretty good. It sounded like something was catching on sheet metal and making a pop. When I saw everything was clear, I had someone yank the wheel and that main shaft from the box was really movin side to side.
This is a pretty old thread...so you probably have it sorted out by now, but I just figured Ide post some of my experience for the heck of it.
Justin
Old Jun 30, 2006 | 04:12 PM
AirwolfPL's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Engine: LB9 305cid TPI
Transmission: TH700R4
Axle/Gears: 10-bolt, 3.42
I have the same problem. I replaced the balljoints with Moog "the problem solver" balljoints last year and it cured the problem a bit, but it still pops a bit when I turn the wheels all the way right...
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
