Wild Steering!
Old Apr 16, 2006 | 04:12 AM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
Wild Steering!
Anyone experience wild steering when putting on wider wheels? I just put on 17 x 9 1/2 Z06 rims all around and I'm not having very much fun. If you hit a lump or uneven surface it wants to turn. When I mean turn I mean I have to fight the steering wheel a little to keep straight. The steering wheel jolts and it scares the hell out of me. I'm going to get it aligned on monday, but I don't think It's that bad. What I have noticed is that every time I put on a wider rim it gets a little harder to handle. I had 15x7's(225 60 16) then I installed 16x8 Irocs(245 50 16) and now 17x9 1/2's(275 45 17). Anything I should check or do?
Old Apr 16, 2006 | 03:34 PM
slickfbody's Avatar
Car: 91 camaro z28
Engine: 350 modified
Transmission: 700R4 modified
Get a wheel alignment, i had to when went to wider rims.
Old Apr 28, 2006 | 05:06 AM
ABJ88's Avatar
Engine: 5.0/5.7
ttt
Old Apr 28, 2006 | 06:02 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
deffinetately try a wheel alignment. thats a good place to start. it most likely fix your problem
Old Apr 28, 2006 | 07:54 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ditto on the alignment.
Check for any obvious issues like loose or worn parts.
Almost willing to bet an alignment with the current rims/tires will clear up 95% of the problem.
later
JEremy
Old Apr 28, 2006 | 09:09 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have a similar problem after going wider and lower profile. It is mostly on roads where the lane is rutted from large trucks
Old Apr 28, 2006 | 04:53 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Yeah, you have to pay the price when running wide wheels in the front. I used to have that problem with the 17x9.5" ROH ZS wheels I had. This time around I am sticking to an 8" wide in the front.........jt
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Marc Brown
Sep 28, 2015 01:40 PM
Night rider327
Sep 25, 2015 04:19 AM
