Need urgent wheel help!
Old Apr 17, 2006 | 02:01 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
I bought a set of Boyd Magneatos over this winter and am having a problem. First, I couldn't use the stock lugnuts, so I went down to Autozone and picked up a set of spline drive lugs with the right thread size for the stock studs. This morning on the way to work, I sheared off three of the lugnuts, so my car is sitting out in the parking lot with 2 lugs holding my passenger front wheel on right now. What kind of wheel studs/lugs are you guys running on your wheels? And where can I get a set ASAP so I dont have to watch my car sit on jackstands while its 60-70 degrees out now?
Old Apr 17, 2006 | 02:46 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
wow I've got magnetos with spline drive lugs.. no probs here so far
(/me runs outside and checks his lugs and studs, whew!)
Old Apr 17, 2006 | 04:11 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Few questions for you:
Did you torque the lug nuts when you installed them?
Did you re-torque them after driving a few miles?
Did you use close-ended nuts?
Did they have a conical seat?
Were they 12mm X 1.5?
Old Apr 17, 2006 | 07:11 PM
DJCobol's Avatar
Dont have a torque wrench, but they were tight
After about 40-50 miles, yes.
Yes
Yes. One of my friends kept telling me that aluminum wheels needed lugs with a shank on them that the wheel could "ride" on instead of the wheel stud itself. Not sure if this is true at this point or not.
Yes
A friend met me at work with my tools. We got the front end in the air, and the passenger side tire pretty much fell off the car. There were only 2 studs left at that point, and one of them broke when the pressure was taken off of it. 2 of the holes on that wheel were ovaled out pretty bad, so it looks like I'll be shopping for a new 17x8 Boyd Coddington Magneato to replace that one. Also, as I was taking the brakes apart to get the old rotors out, I noticed that I'm missing a caliper slide pin. Talk about sh*tty luck.
Old Apr 17, 2006 | 07:17 PM
DJCobol's Avatar
While I'm replacing all this stuff, can you guys reccomend some better studs/lugs to keep this from happening again?
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
