90/10 drag struts on the street?
Old Apr 18, 2006 | 06:54 PM
jonarotz's Avatar
Car: 91 Z28
How many of you guys run 90/10 struts on the street? My car is mostly going to be a weekend warrior with some trips down the strip just wondering if I should take out the KYB's in favor of some weight transfer with some 90/10's.
Old Apr 18, 2006 | 07:13 PM
brutalform's Avatar
Some members posted on the Drag Racing and Autocross board are running them, some with Moroso trick front springs, no less. IIRC, they are not so bad. Try a and maybe you can read up on it. I know IHI had mentioned it once or twice.
Old Apr 19, 2006 | 06:40 AM
Shagwell's Avatar
Car: projects.......
I along with everyone I race with won't even run them on a drag race only car. Do you want air under the car while going down the track? Because the 90/10's don't settle back down, which keeps the front of the car high, thus allowing more air under it, making it more unstable. They also tend to "float" around alot under deceleration.
- How about tuning the suspension/shifting some weight and improving your 60' the right way?
note: the slowest car I'm talking about is my 11.7X bird. But, slower than that doesn't cut it for me. - My old man's elcamino tow truck ran 11.7's.....
Old Apr 20, 2006 | 07:51 AM
383firebird84's Avatar
Car: 84 firebird
Engine: 434ci
Transmission: turbo 400 3500 stall transbrake
Axle/Gears: 10 bolt 4.10 spool'd
i run 90/10s on the street on turns its a little scary but other wise they are ok also you should have some moroso trick drag springs
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
