my overkill suspension setup
Old Apr 22, 2006 | 11:21 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
well after I destroy my old 3.23 open 10 bolt i decided to ugrade my suspension while being there.....
so here my old bent panhard bar beside the new adj rod end bar
installed pic with the new 1" rear swaybar
the new adj rod end lca installed
that was enough for the rear the front a litlle 1"7/8 swaybar with an iroc wonderbar
i know its overkill but i got a good deal on the part and it remove all the wheel hop.
Tanks tell me what you think
Seb
Old Apr 22, 2006 | 11:24 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looking good. do you have sfc's?
Old Apr 23, 2006 | 05:50 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
its a part of the next step but they will be weld in but ill redo the body before. I need to completely strip the car and remove the powertrain for this so its more of a fall/winter project.
Seb
Old Apr 24, 2006 | 12:16 PM
Shagwell's Avatar
Car: projects.......
subframes and torque arm and you'll be in business......Also, not sure what type of rod ends you used, but for straight line traction on street tires, poly ends tend to work better on the lca's. Takes a little of the shock out and allows the tires to stay planted.....If you're more into handling, disregard.
J-money
Jan 4, 2019 09:45 AM
customblackbird
Oct 1, 2015 04:30 PM
fasteddi
Sep 10, 2015 09:32 AM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
