control arm trouble
Old Jun 3, 2006 | 08:54 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
control arm trouble
im having a bit of trouble putting my control arms back in. im tring to do this without a compresser. i can get it jacked up and attach it the the spindle but im having difficulty getting it to bolt up with the pivot bolts. pretty much what i need to kno is how you guys have done it, whats the easiest way. i tried searching but had only a lil luck, no clear answers. any help would b awsome as id like to get her back on the road. thanx alot
matt
Old Jun 4, 2006 | 01:07 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
jack it up on the innermost edge, that lip, between the two bushings. Use a crowbar, or big screwdriver, to force the bushing into the slot in the k-member, it will want to twist. make sure front and back are sliding in right. You may have to put a jack stand under the lip/spring perch, and move your jack to right below the bushing itself, and jack there, get one in, then do the other one. They aren't easy, that's for sure. It'll be too far out/in, so you can pry it outwards, and/or lower the car a bit to bring the a-arm in a bit. You'll have to play with it to know what I mean.
Old Jun 4, 2006 | 03:28 AM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Check out this thread I posted a couple days ago.
https://www.thirdgen.org/forums/susp...ll-set-me.html
There were a lot of helpful tips in that thread, and a couple other links. After they responded to my thread, I got them in that night. I used the method RBob suggested.
I suggest having help. We had 3 people do it, and they went in fine. Good luck!
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
