Anyone running a 15"x10" rim on a 9-bolt with discs?
Car: 1989 Iroc-Z
Engine: 350ci SBC
Want ot get a set of rims for the rear but need to know if the 9-bolt disc brakes will clear a 15"x10" rim. Also what back spacing and tire size would you recomend?
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I run 15x10s with 5.5 backspacing on my 87,but I understand that there was a caliper change in 88.This is not me stating a fact,just saying if I understand correctly,the disc brake setup changed,I'm sure one of these other fellas can give specifics.
If you can get the 10s on the rear,295/50s are a nice choice for a rear tire.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Back when I had a 9 bolt, that's what I ran. 15x10 with 5.5" backspace. I still use the same rims but the tire has gotten wider and taller.
Car: 1989 Iroc-Z
Engine: 350ci SBC
The rims I am looking at are the Centerline Warriors but they only come in a 5 inch backspace. Will this be a problem? Also with a 5in BS what size tire will tuck into the wheel well? I was thinking a 27 or 28in 9-10 in width??? Anyone running a similar combo???
I think a 5" backspace woulb be ok,you might end up trimming the lip in the wheelwells a bit,not too sure.A 275/60 will spread niceley on a 10" wheel,and be roughly 28" tall.
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
