Monro sensa trac good or bad?
Old Jun 28, 2006 | 08:51 PM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Are these good or bad? If bad can you suggest a good brand. Thanks.
Old Jun 28, 2006 | 08:55 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
That depends. If you're looking for performance, then there are definitely better things out there. But if you just need something to replace the worn stock ones, then they're okay.
KYB makes some slightly better shocks/struts for not too much money.
Old Jun 28, 2006 | 08:59 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
I'm looking for better performance I read a article with a car that had formula gp's. Are they much better? What would you suggest for road and not too much $. Which KYB's would be best? How are the KYB GR2?
Old Jun 29, 2006 | 11:55 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I am sure some will get on here at talk trash, but I have sensatracs and I autocross my car every chance I get. I think they are just fine. I do well at autocrossing compared to cars similar to mine with street tires. they also seem to work well on the road in normal driving conditions as well. I didnt want to spend a fortune on Konis or Bilsteins when I was doing my suspension work and I am happy with my Monroes.
Old Jun 29, 2006 | 06:55 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Thank you for the input. I will keep that in mind but I'm also looking for recommendation on other ones that may be better. I'm thinking about getting the KYB GR2 are they any good?
86IROC112
Apr 9, 2016 10:20 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
