Loud series of knocking
Old Jun 30, 2006 | 03:14 PM
Stevo's Avatar
Car: Pair of 92 Z28s
At slow speeds and when i park my car im getting a loud series of knocking coming from the front end. Sitting still turning the wheel back and forth to full lock i get like 4 thunks right before its turned all the way to the right. It clunked when i got the car some when pulling into parking spaces but a complete front end rebuild made them all go away. I just recently about 3 months ago lowered the car added a wonderbar and new sway bar bushings in the front.
Ive watched the front end when someone turns the wheel and everything looks nice and tight, no play when i shake the wheels.
Stuff that hasnt been changed:
Front Strut Mounts
Front Struts
Balljoints
Front Control Arm Bushings
Original Steering box and rag joint
All those havent been touched.
Im sure the car needs struts but how bad can the struts really be in order to make really loud poping noises?
It sounds like its coming right from the middle of the steering column. I pulled the cover back and have watch all around there and there is no play or movement. It doesnt sound like its inside the steering box but it happens right where it mounts. No frame cracks whatsoever nothing is rusted.
I have been plannin on getting struts on the car but not for over another month.
Thanks in advance for the help.
Old Jun 30, 2006 | 03:43 PM
AirwolfPL's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Engine: LB9 305cid TPI
Transmission: TH700R4
Axle/Gears: 10-bolt, 3.42
Originally Posted by Stevo
At slow speeds and when i park my car im getting a loud series of knocking coming from the front end. (...)
Front Strut Mounts
Front Struts
Balljoints
My bet: Balljoints (worn balljoints sound like hull of the submarine that cracks under the pressure, when you turn your steering wheel fully ) - I replaced my balljoints last year and it pretty much gone away (it still does this 'cracking' sound but it's not as loud as it was before).
PS.: This is my first post on this board so HELLO from Poland. I registered long time ago, but I couldn't post for some reason, and admins didn't wanted to help me...
Old Jun 30, 2006 | 03:55 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
have some one turn the wheel side to side while you watch the steering box. check and make there is zero movement of the box while the wheels are being turned.
Old Aug 30, 2007 | 10:08 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Loud series of knocking
I know what you mean Stevo, my car has about 136,000 miles and it makes the noises when I turn the wheel all the way to the left and all the way to the right.
I want to autocross my car but this knocking sound is giving me second thoughts.
Old Aug 30, 2007 | 09:47 PM
L69norm's Avatar
Ball Joints or center link joints. Both made weird popping noises when they went bad. Get it looked at. I had a ball joint let go while I was driving slow and it made a hell of a mess. Took 2 hours to get it hooked up to one tow truck with a second truck to help. They even called a supervisor who showed up in a third truck on his day off. Wouldn't want it to happen on the expressway.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
loud91rs
Oct 5, 2015 10:05 PM
efiguy
Sep 27, 2015 01:30 PM
tgp1990
Sep 4, 2015 06:24 AM
