would these wheels fit on my car???
Old Jul 18, 2006 | 06:31 PM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
i have a 1991 bird will the konig troubles fit on our cars? i think they look hot
Old Jul 19, 2006 | 07:46 AM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
no one knows?
Old Jul 19, 2006 | 03:23 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
What are the wheels dementions??
Old Jul 19, 2006 | 03:33 PM
luisote's Avatar
Car: Camaro IROC-Z 1987
Engine: 454 BIG BLOCK
Transmission: TH700R4
Axle/Gears: 3.42 gears Posi trac
the third gen camaros have in the front a 0 offset and a backspace needs of 4.75 inches and in the rear the offset is the same and the backspace is 5.25 inches
That's why someones have wider wheels on the rear because de backspacing is different from the front ones
Old Jul 19, 2006 | 03:44 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
First, people need more than a name to tell you if they fit. You can't expect them to do all the work.
Second, wrong board, as per the sticky at the top called "Before you ask if your wheels/tires fit..."
Old Jul 21, 2006 | 09:17 AM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
well now i apologize i was in a hurry when i posted this, but the PCD is 5x120 and the offset is 40, they are listed as fitting a 1993 trans am and im wondering if u could put them on a thirdgen
Old Jul 21, 2006 | 08:20 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
If they'll fit a '93 then I imagine you could use them with spacers, like all other 4th gen wheels. I could be wrong though.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
milk
Aug 10, 2015 06:26 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
