Entire Suspension
Old Jul 26, 2006 | 02:37 AM
88ChevyThunder's Avatar
Car: 88 Chevy
Engine: TBI 350
Transmission: 700R-4
Axle/Gears: Jegs Axle and 343 gears/Posi Unit
Entire Suspension
Can anyone post up a picture or a description of a stock 1991 Rs Suspension all the way around front and back?> Thanks
Old Jul 26, 2006 | 12:04 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
What type of info are you looking for?
The front is an independent setup has lower control arms with a coil spring and a strut. The lower control arms are tied to the frame via a sway bar to control body roll.
The rear is a live axle with coil springs and shocks. It is held in place front to rear by the lower control arms, rotationally by the torque arm, and side to side by the panhard rod. It may or may not have a rear sway bar.
LT1Formula
Oct 8, 2015 08:34 PM
Luigytico09
Oct 1, 2015 08:46 AM
