Do new tires get wider as they settle, my new 245's look like 225's right now.
Car: 1994 Trans Am
I just bought a set of brand new Kumho Ecsta 245/50r16 tires. Unmounted they looked fine and wide. But now that they are installed they look very skinny.
Do tires do that? Will they settle and widen as the weight and handling is put upon them?
It just seems weird. Tires that were on there were the same size and looked much wider. But I wasn't the one who installed them. I haven't bought a set of tires for a Trans Am in 7 years.
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
They won't widen, but the tread pattern will eventually get wider as the tire gets flatter.
Car: 1994 Trans Am
Sorry, I meant tread pattern. Derrrrr.... I thought it would widen out. Also, I checked the psi on them and they were above 50psi. So I lowered them back down to 35. I like it there because all the bumps in the road rattle the car. But 35psi softens it up quite a bit.
Thanks guys.
Thanks guys.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
What they said.
U take 3 different 245/50-16's from 3 different manufacturers and they will all have different widths and heights.
Its how it works
later
Jeremy
Its how it works
later
Jeremy
Car: 1994 Trans Am
Originally Posted by 82 Iron Duke
Hey Kev whats going on bro,
Those are some nice tires and yes, I would stay at 35 psi also. Make sure you check the pressure once in awhile
Hey Lawrence, I actually just started using those rubber arms you sold me months ago. I cut the tips off the arms and used a dremel to slice off 1" of rubber from the base of the tip to expose the bare metal. Soon I will cut open the wing and glue them in there and use some sort of bondo like stuff for rubber and hopefully it will hold.
Guys, I know about tire companies being different with sizes. I just wanted to know if the tread will widen with age. Question answered.
morrow
Jan 13, 2024 12:29 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
