slicks
What rims do you plan on using? I fit 27" tall et streets with no problems, on a 15 inch wheel, with 5" of backspacing. Others on these boards have fit larger with little or no fender persuasion. Choosing the proper back spacing of the wheel, will play a big part in fitting larger tires. Welcome to TGO, BTW.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Not very big without front inner wheel well massaging.
Biggest I've run is 28x11.5 Hoosier quick time pro's, 29.5x9 MT full slicks on a 10" rim with 5.5" BS
I did have to beat on the front inner wheel well for clearance and cut out the bump stops over the axle.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I ran some 28 x 9 ET Drags with no modifications. Had them mounted on some 10" wide rims with 5.5" backspace.
I'm currently up to 29.5 x 10.5 ET Drag slicks but I also have a much of inner fender modifications to tuck them in.
Width measurements depends on the tire ratings. A 9" slick is the width of the tread. The sidewall is even wider. A 10.5" DOT tire can have the the same tread width as the 9" slick because a DOT tire width rating is the sidewall width.
Quick time pro tires are a DOT tire. So are MT ET Street, BFG Drag radial, Nitto etc.
When someone mentions "slicks" I have to assume they mean a track only slick so the tire width is the width of the tread.
Originally Posted by slowmaro13
what do you think about a 325/50/15 on a 10 inch wide rim with 5 inch backspacing or should i go with 5.5 backspacing
I'm thinking about running a 295/50/15 on a 15 by 10 rim with 5.5 backspace that should fit under there pretty snug huh will i have to take the rearend rubber stops off i guess i'm just trying to get an idia how close its going to be?
