Lakewood Trac Bars
Old Aug 1, 2006 | 04:59 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Lakewood Trac Bars
I have a set of Lakewood trac bars that I have had on the car for awhile. I was wondering if anyone else has used these and what sort of adjustments did they find were giving them the best results. I have a moser 9 and those bars with 4.56 gears along with 295/65/15 MT radials and it seems that they still dont hook all that well When leaving on the transbrake. I would have thought it would not spun as much as it does! What kinda tire pressures are you guys running with those MT slicks?
Old Aug 1, 2006 | 05:53 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
just wondering but do you have relocation brackets or a torgue arm it helped my car out alot but it more of a difference when i put on the relocates i havent drove the car since the torgue arm but i will let you know as soon as i do Later Daniel
Old Aug 1, 2006 | 05:55 PM
izcain's Avatar
Engine: 584
I still have the factory torque arm. As for the brackets... The lakewood trac bars bolt right to the axle housing using a set of brackets so I guess I would say that they are relocated but Im not sure do you have a pic I can see?
Old Aug 1, 2006 | 06:19 PM
brutalform's Avatar
Once you do hook, those bars will probably break. I have two friends that broke them. If/when they do let go, I would recommend a set of Spohn anti squat brackets instead. I do not know if Lakewood improved the brackets, but, don't be suprised if they break.
As far as the tire pressure, you have to experiment, as every car is different. Try 18 PSI, and work down from there.
Old Aug 2, 2006 | 01:19 AM
izcain's Avatar
Engine: 584
What part of the brackets have you seen break? The drivers side bracket already looks partially bent so I think I will change them out anyways.... You said the spohn ones are better? These are adjustable and everything? Thanks for the reply!
Old Aug 2, 2006 | 07:08 AM
brutalform's Avatar
Not sure what part of the brackets break. The Spohn brackets are inexpensive. They must be welded onto your stock LCA brackets on the rear. They are adjustable, so you can move the LCA in different positions. This is basically what they do.
https://www.thirdgen.org/forums/susp...arm-angle.html
Old Aug 2, 2006 | 08:34 AM
izcain's Avatar
Engine: 584
Thanks! that was a simple way to explain things and it made perfect sense lol. I will definitly be switching those out sometime soon!
Old Aug 2, 2006 | 01:00 PM
Shagwell's Avatar
Car: projects.......
- if you do a search on the lakewood "traction action" bars, you'll find many reason to take them off.
- Put a set of lca relocates on and the a set of boxed or tube factory replacement lca's(lakewood makes a good set of these cheap) You'll find much more traction this way.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
