Whats the noise in the front!
Old Aug 7, 2006 | 12:46 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
ok i finally did a front end rebuild this weekend on my firebird. i noticed a clunk/popping noise coming from the passenger side suspension. it does it every once in awhile when i accelerate hard. it does it when i step on the brakes or if i hit a bump or something on the road. is it my a-arm? did i forget to tighten something? let me know thanks
martin
Old Aug 7, 2006 | 01:34 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I had this proble before in my Z, on mine it turned out to be loose K-member bolts on the passenger side. Went in and tighend em back up and the sound was gone.
On yours I would make sure the swaybar endlinks havent broken. That seems to be a common problem on lots of cars, and most people dont see the broken endlink cause it "looks" like it fine.
Just get back under the car and start checking bolts with a wrench. Use a pry bar to check swaybars, control arms and what not. Just pry on it a little to see if it starts moving around. Hope that helps.
Old Aug 7, 2006 | 01:58 PM
1Bad3rdGen's Avatar
Engine: 305 L03 TBI
Axle/Gears: Stock
ok ill do that. and the sway bar link is brand new. but im going to have to check when i get the car back from alignment. thanks
Martin
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
BlackBoulder
Aug 11, 2015 11:15 PM
