Can I use these 97 Vette rims????
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
My buddy gave me a set of aluminum vette rims... the back two are 18x10.5 and the fronts are 17x.9.5 can I make these fit my car? if so what tires should I get? I know I need spacers...thanks so much
Yes you can use them.
They bolt right on, with 2" spacers. The fronts might look a bit better with 2¼" or 2½" spacers, but if you do that, the outer edge of the tire may rub on the fender at the bottom rear of the wheel opening, when the steering is turned near lock.
I have those wheels on my car, with 2" spacers all the way around.
My tires are the Pirelli P-Zero Nero all-weather. Stock sizes for the Vette; I can't recall for sure, but they're something like 275/45-17 front and 315/40-18 rear.
Car: GTA
Engine: 383 HSR
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
