Will these rims fit without to much effort?
Old Aug 24, 2006 | 02:21 PM
iiiluckyboyiii's Avatar
Car: 89 camaro rs
Engine: 305 tbi soon 78 lt1 400hp
AXIS SEVEN/7/SE7EN MODEL RIMS IN GUNMETAL! 5 LUG, PATTERN- THEY WERE MOUNTED ON A LATE MODEL Z28, AND AN S10 EXTREME- 6-6.5" BACKSPACING other than spacers what will i need to do for these to fit if i actually decided to buy them will they just bolt up like they did with the 95 z28 and not rub or will i have to grind some things down or mod anything? ? my car has not been lowered and has all factory suspension and stuff. what other info do i need if any for me to know if they will fit?
TIRES ARE 245/35/19 FRONTS low profile
19x8,19x9
AND 275/30/19 REARS low profile
Old Aug 24, 2006 | 03:10 PM
Car: 89 camaro rs
heres a pic
Old Aug 24, 2006 | 03:12 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Spacers should cover it.
Old Aug 24, 2006 | 03:21 PM
Car: 89 camaro rs
sweet so they wont rub or grind or anything like that? or if they do very little?
Old Aug 24, 2006 | 03:44 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
if they fit on a fourth gen there should be no problem getting them to fit on a thirdgen if you have the spacers for them.
Old Aug 24, 2006 | 04:05 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
They shouldn't. But double check before you drive it anywhere.
Street Lethal
Apr 30, 2019 12:14 PM
Djmathis123
Sep 29, 2015 01:36 AM
Gambit TA
Sep 1, 2015 07:27 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
rh76camaro
Aug 29, 2015 11:04 AM
