sfc clearance issues with dual cat exhaust
Old Aug 25, 2006 | 05:54 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
My 91 GTA has dual cat exhaust. I just had spohn's 3 point sub frame connectors installed by J.S. Performance in P.A. Unforunately, they could only install them as 2 point subframe connectors because of clearance issues with one of the cats.
I was thinking about deleting the cats and replacing them with straight tubing. But, this will cause me to fail emissions. Any ideas?
Thanks,
Bill
Old Aug 25, 2006 | 11:55 PM
irocyourpants's Avatar
Car: iroc
When EBMiller installed mine he just took out the heat shield above one of the cats and the other bar fit fine.
Old Aug 26, 2006 | 12:16 AM
laiky's Avatar
i cut out a strip from the heatsheild equal to the width of the bar. welded the bar then reinstalled the sheild as 2 pieces.
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Out-Cast
Aug 22, 2015 07:49 PM
Jlanz55
Aug 17, 2015 07:15 AM
