Another Front Spring Q?
Old Aug 28, 2006 | 12:07 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Ok I'm pretty sure I have this worked out but wanted to be sure so here goes
A thirdgen uses a 5.5 inch diameter front spring so any standard circle track spring would work (bassically) but most are too short so you need a weight jack or a spring spacer to take up the extra distance
So could I use something like this
Here
Placed on top of the and a regular 9.5 x 5.5 inch circle track spring?
Also would it be nessacary to tack weld the spacer to the upper spring bucket?
And would a 900 Lb spring rate be a decent choice for this I'm looking for a pretty firm ride and going for a kind of low buck pro touring thing with my car (jack of all trades master of none)
All feedback is appreciated
AL
Old Aug 28, 2006 | 12:30 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
900lb/in spring rate?!?! Are you sure that's what you want? That would be like riding a skateboard... Street driven?
I mean, I use the moog 5664, which is 750ish lb/in, compared to the stock 5660 on my car, 560lb/in, its rock hard. I like it though. I think 900 would be pretty excessive though.
Sorry, I don't have any useful technical help for you, just making sure thats what you want to do.
Old Aug 28, 2006 | 10:38 AM
Car: 89 Formula
I really dont see it being to stiff...........but the good part about using stock car springs is that there cheap and readily avalible in many different rates should I want to change later down the road
And yes it will be street driven
Old Aug 31, 2006 | 04:11 PM
Car: 89 Formula
A little help here I'm pretty sure I got it right but I just want to be 100% sure
Old Sep 1, 2006 | 08:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I used the AFCO adjustable spacers and springs on the 1st gen. Great way to go, easy to adjust the height, and a wide selection of spring rates.
To fit the upper pocket the top of the spacer was tapered from 0 to 1/4 ". this allowed the spacer to sit square to the spring. They aren't welded in, the spring pressure holds it in place.
On a 3rd gen the spacer can be placed in the lower pocket. No shock to deal with.
RBob.
Old Sep 1, 2006 | 12:31 PM
Car: 89 Formula
Thanks thats all I needed I just wanted to be sure after all Ill be the fool driving in it LOL
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
TA8487
Aug 11, 2015 09:02 PM
