hey guys, need some advice picking out some new sfc's. i had the hotchkis square tube ones on the car, but i had to cut them off due to exhaust clearences. im running the edelbrock headers with the 3 inch y pipe. any advice? my bird is a t top car so i need the support.
thanks phil
thanks phil
i like my jegs brand bolt-in style that I also welded in. The bolt in brackets allow for more area to be welded to the vehicle
JamesC
close
I have Global West's version. No interference with Hooker 2055 Y-pipe, no loss of ground clearance.
JamesC
JamesC
I used the JEGSTER SFC's that can also be welded after install; these are ran with a Hedman y-pipe and headers. Everything installed with no mods needed.
yea, my hedman headers and y-pipe interfered with my hotchkis SFC's.... So I fixed the y-pipe, not the SFCs!!!
Why would you chop your $300 SFC's when you have a problem with a $100 y-pipe?
Anyway, looks like these others will work with a y-pipe though....
