Sway bar diameters
Old Oct 17, 2006 | 09:02 PM
Irocman86's Avatar
Sway bar diameters
for a stock 86 iroc with 305 and tpi and 700r4 trans and 3:42 gears
for the front and rear swaybars cause i want polyurithaine
Old Oct 18, 2006 | 05:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll have to measure to be positive. Put a crescent wrench on the bars here and there and measure the gap.
JamesC
Old Oct 18, 2006 | 08:26 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Most likely you have 34mm front and 23mm rear. You'll need to measure them to be certain.
Lon
Old Oct 18, 2006 | 03:59 PM
86irocterror's Avatar
my 86 iroc has 30mm front and 24mm rear stock. mine is the FE2 rpo code. look in your center consol for these rpo codes.....ZK3 = 34mm front and 21mm rear......FE2 = 30mm front 24mm rear....you should see one of these 2 codes. there are a few others i have but they are for other models, i think these are the only 2 codes for the 86 iroc. hope this helps. in 86 the only front bars were 27, 30, and 34mm and rears were 18, 21, and 24mm on the camaros. some people say 36mm for fronts but there are NO rpo codes that ive found that say it was available in 86. i could be wrong though if there is a code and someone knows it please post it for my to add to my records. anyone like to buy my stock bars let me know. i now have hotchkis hollow bars on now. 1 7/16" front and 1" rear, roughly 36mm and 25mm
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
