What would you do
Old Oct 26, 2006 | 11:00 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
What would you do
If you could have one or the other what would it be? (better for traction, lower 60' time)
-Tubular Panhard rod (non adjustable)
-Boxed LCAs
Trying to throw some hints at my girlfriend for xmas.
Old Oct 26, 2006 | 11:10 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I'll take C. Some sticky tires.
The panhard won't help at all for 60'. And although LCA's help a bit, you need to get to the power to the ground, all the cool suspension stuff in the world is no good, if the tires can't grip.
Old Oct 26, 2006 | 11:13 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
