what to get koni/bilstein,what sway bars where to find adjustable ones?
Subscribe
Nov 1, 2006 | 07:29 PM
What struts and shocks should I get for my car? go with a set or one brand inthe front another in the rear? who has the best price link/tele#.
Also what sway bars should I go with? who makes adjustable ones?
Which would make a bigger diff, struts and shocks or the sway bars in terms of handling? my mods are below.
Reply 0
Nov 2, 2006 | 05:46 AM
Quote: Also what sway bars should I go with? who makes adjustable ones? Which would make a bigger diff, struts and shocks or the sway bars in terms of handling?
Sway bars aren't adjustable. The hollow 36/solid 24 combo is a nice stock set-up (as good as it gets from GM, and I believe they're still available). Personally, I'd replace the struts and shocks first. Aside from the sway bar bushings and end links there's nothing to wear on the sways.
JamesC
Reply 0
Nov 2, 2006 | 06:27 AM
I think I have the 34/19 combo,what aftermarket ones are good?what size?where can I get them? Haveing the size I have would you still do the struts and shocks first?
what struts and shocks?
Reply 0
Nov 2, 2006 | 06:46 AM
Quote: I think I have the 34/19 combo,what aftermarket ones are good?what size?where can I get them? Haveing the size I have would you still do the struts and shocks first?
Many aftermarketers sell varing sizes of sways. Check Spohn for example. I'm not pushing the 36/24 combo by any means, but it does allow for some spirited driving (I'm not an autocrosser so I've not tried different combos, but I am pleased with what I have). Yes, I'd still go struts/shocks first. Type? Now there's a question with a million and one responses. Me, I'm going Bilstein or Koni Reds when the time comes.
JamesC
Reply 0
Nov 2, 2006 | 12:39 PM
What is the diff between the yellow and red? pros/cons of each(koni) thanks
Reply 0
Nov 2, 2006 | 01:54 PM
Sells both bilstien and koni's call them up and tell'm what you have and what youre looking to improve.
STRANO Performance Parts
68 White Street
Brookville, PA 15825
Strano Performance Parts provides auto parts for your car or truck needs.
Order line: 800/729-1831
Tech line: 814/849-3417
Reply 0
Nov 2, 2006 | 02:44 PM
The link below may be of some value to you. Shox.com
Bilstein shocks, Bilstein PSS, Koni, BOGE, Eibach, K&N and other name brand suppliers
Reply 0
Subscribe
