Rear suspension questions.
Old Nov 12, 2006 | 10:31 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Im pretty much an idiot when it comes to the suspension of a car. When I was getting my rear tires replaced I was looking at the empty rear drivers side wheel well. Part of the suspension, on the left side *front of car side*, there was this bar with rubber gromet things on top and bottom, it was VERY loose. Im talking VERY loose. Im assuming its not suppose to be like that. What is that piece called so I can replace it?
Old Nov 12, 2006 | 11:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Sounds like you have a rear sway bar and it sounds like your sway bar end link bushings are shot. Go order a new End Link kit for a rear sway bar.
Old Nov 13, 2006 | 04:48 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
=] Thank you.
bjpotter
Jan 22, 2019 12:27 PM
lt1z350
Aug 28, 2015 05:57 AM
cam-mike
Aug 24, 2015 07:23 AM
