Rear Suspension what do you think?
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Here are 2 shots of my rear suspension what do you guys think good setup bad setup?
The parts list I have are Spohn panhard bar\, Bmr Panhard relocation\ lakewood LCA's\ Bmr lca relocators\ Eibach pro kit\ Kyb Gr2 shocks\.
its supposed to allow for more clearence with getting exhaust pipes over the axle. The way it looks right now i may be able to get two-two and a half inch pipes over the axle for true duals
ya my car is sitting real low to the gound in my uncles garage and he has a bunch of stuff around it so i just held out the camera and took some pics
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
No rear sway bar?
LCA RB's are non-weld in? You planning on welding them in anyway? (i'd go for it
hmm, GR2's? Why go entry level when you're upgrading everything? Just kinda sounds like putting Koni shocks on with saggy springs... well, maybe not, but just wondering if there was a reason for those over, gas-a-just's, or Bilstein, etc?
)hmm, GR2's? Why go entry level when you're upgrading everything? Just kinda sounds like putting Koni shocks on with saggy springs... well, maybe not, but just wondering if there was a reason for those over, gas-a-just's, or Bilstein, etc?
im still a student in high school so my my car fund ran out and the reason or no rear sway bar is the car is completly taken apart its been sitting in my uncles garage for 7 years and he decided to sell it to me the body it self only has 23,000 oringinal miles on it but as for a sway bar i plan on putting on the spohn drag series sway bar
bjpotter
Jan 22, 2019 12:27 PM
