WS6 on 91RS
Old Dec 3, 2006 | 06:57 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
WS6 on 91RS
Would it be too difficult to mate the WS6 suspension package with rear discs to a 1991 V6 camaro RS?
Old Dec 4, 2006 | 07:14 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Well, the rear will fit and so will all of the suspension pieces. The problem is that the wheels will be sticking out 2" farther.
Old Dec 4, 2006 | 08:51 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
What year is the WS6 stuff from? If its from a forth gen the rear will make the wheels stick 2" out but if it from a third gen then theres no problem.
Old Dec 4, 2006 | 01:02 PM
draco's Avatar
Engine: 5.0l TBI
the ws6 kit will be off of a 1984 Recaro Trans am. Hopefully anyways lol.
Old Dec 4, 2006 | 01:58 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
All suspension piecies will fit then. With the exception of the front springs. Since your car is a V6 the springs are different for a V8. You should be able to bolt everything in. Just make sure you get the correct proportionating valve for 4 wheel disc brakes. It just bolts in place of the old one. I did a similar swap on my 92 RS. I swaped in a GTA disc rear from a 91.
Old Dec 5, 2006 | 08:28 AM
draco's Avatar
Engine: 5.0l TBI
Alright, will do!
Thanks again for the information!
~Austin
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
dbrochard
Sep 7, 2015 09:41 AM
neekolzun
Aug 24, 2015 04:59 PM
