Installing the adjustable camber/caster plates from J&M Products
Old Dec 10, 2006 | 03:19 PM
GTA89's Avatar
Car: Pontiac Trans Am GTA
Engine: 5.7 350
Transmission: TH700R
Hi !
(i used the search engine, but didn't found the right answer)
I m planning to install the adjustable camber/caster
plates from J&M Products since the old plates are gone.. .
Anyone have experience with this ? what's should i know and
what do i need ? which tool for alignment etc ??
Can you also tell me the best settings for street and track use ?
Is it easy to shift to another position or do i need to re-align
by a "wheel-align centre"
Thanks for help, below you can see which one i have..
Bye !
I have also one more request :
If you also have the same set, please show me a pic of this installed.. thanks !
Old Dec 11, 2006 | 08:02 AM
GTA89's Avatar
Engine: 5.7 350
Anyone ?
Old Dec 11, 2006 | 02:15 PM
Shagwell's Avatar
Car: projects.......
You'll need to have it re-aligned by someone with the proper equipment (i.e. a tire shop). Unless you really know what you're doing. It takes some work to properly adjust caster and camber. I spent almost 2hrs getting perfectly where I wanted, and I was using the a laser Hunter DSP900 alignment rack.
Most decent shops can set you up for what you want. For aggressive handling you'll want them to stay to the low (negative) limit on the camber, but as long as you keep it with in factory specs, tire wear will still be decent enough.
Old Dec 12, 2006 | 12:21 PM
GTA89's Avatar
Engine: 5.7 350
Hi thanks for help !
Where did you get that DSP900 ? Is this a "mobile" align rack ?
And also tell me the factory settings, or the settings which
u will recommend me... i m using the car mainly at street.
but sometimes at track..
thanks !
Old Aug 16, 2007 | 10:49 AM
jayg's Avatar
Car: 1992 Formula 350
Re: Installing the adjustable camber/caster plates from J&M Products
How much negative camber were you able to get out of these?
Old Aug 16, 2007 | 04:56 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
They have been redesigned since then, so you might wanna call J&M to get the new specs.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
dcbsracing007
Aug 18, 2015 07:24 AM
bryan623
Aug 10, 2015 11:33 AM
