Spohn A-arms
Old Dec 18, 2006 | 02:27 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Axle/Gears: 2.77 9 Bolt
Spohn A-arms
Anyone here buy Spohn's A-arms with spring boxes (part #732)? I was thinking about getting the chromoly ones but saw a pic of one that broke at the weld for the sway bar end link.
https://www.thirdgen.org/forums/afte...t=spohn+a-arms
I'm going to do a full brake job and figue if I have to take off the rotors and put new wheel bearings, I should upgrade the A-arms, too.
Old Dec 18, 2006 | 05:39 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
That's kind of like changing the bearings just because you have to change the oil, but the reason that tab broke is not because it's made of 4130 or improper heat treating, it's because the tab is designed poorly. That failure will happen eventually with every piece, the contributing factors (sway bar size, sticky tires, etc) will determine how many cycles until failure.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
