Driving Dangerously....
Old Dec 19, 2006 | 03:41 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
So I noticed the other day that my wheel is knocking while im driving. Last time that happened was when my lug nuts were loose. So today I grab my dads tire iron and went to tighten the bolts.. um.. so there are only two bolts holding my tire on.. one of them wont tighten and the others broke off some how.. This is scary.. I dont know anything about that stuff other than how to take a tire off and change the brakes.. Ive never had to replace the studs before..
Every bit of help is greatly appreciated considering I could kill myself or someone else if I dont get this taken care of asap.
Old Dec 19, 2006 | 03:53 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Get new studs.
Drive the old ones out and drive the new ones in.
1-2$ a piece and away u go.
I usually use a stack of washers to pull the new ones thru and seat them
later
Jeremy
Old Dec 19, 2006 | 04:13 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Okay cool.. I thought it was going to be expensive/and or a pain in the rear to deal with.
=] Thank you.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
