what would you recommend
Old Dec 26, 2006 | 02:59 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
My iroc ran into a curb at 20-25 mph theres suspension damage and a tear on the frame/body where the a arm mounts. right now the car isnt drivable... should i pull apart the front end and fix whats needed and drive it to the frame shop(would it be safe to drive it with the tear) or have it towed there first then take it home and rebuild the front end?
Old Dec 27, 2006 | 04:05 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
id have it towed
Old Dec 28, 2006 | 09:16 PM
CrazyHawaiian's Avatar
Car: too many ...
Got any pictures of the damage? The A-arms attach to the K-member, luckily it can be removed and replaced with another K-member out of another car. So if it was just the K-member that got damaged then you might be able to fix it for relatively cheap. But if the frame itself was damaged then you're looking at alot more work. The K-member itself is not that hard to remove, but the process of getting to it can be a pain. The engine needs to be lifted out of the bay, and the front suspension needs to come apart. I would source the replacement part from the junkyard, the K-member is a strong piece and not a wear item, as long as its not rusted or bent then its good. Usually when jumping curbs the A-arm, balljoint, strut mount, and steering linkages get hammered. If the damage was extensive enough to reach the K-member you might really want to check all the suspension components out. Make sure things aren't bent before putting them back on. Make sure bushings wern't damaged. When everything is back together have a frame shop check it and a realignment will be required.
Old Jan 4, 2007 | 10:56 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
That's doing it right and also paying a lot to make it so (if you have someone do ot for you).
F-body-fan
Jan 12, 2023 01:49 PM
Pac J
May 17, 2020 10:44 AM
drumstixer
Sep 29, 2015 03:02 PM
Zell1luk
Sep 29, 2015 10:36 AM
kitt23
Sep 26, 2015 07:48 PM
